- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
- To connect to the machine using SSH, follow the Azure instructions.
Alternatively, you can connect to the machine on your terminal using SSH:
# If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm># If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Log in to the machine via SSH using the following commands:
If you set a password:
ssh <user>@<dns_of_vm>ssh <user>@<dns_of_vm> -
If you used an SSH key:
ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Identifying the Device Name for the Disk in Azure
The disk device name is different from the disk name. You will need the disk device name when configuring the disk.
To configure the disk for installation, see the following:
These additional inbound ports are needed only for multi-node HA-ready production installations. Add them to all VMs.
Port |
Protocol |
Source |
Destination |
Purpose |
443 |
TCP |
Any |
Any |
https traffic |
2379 |
TCP |
VirtualNetwork |
VirtualNetwork |
etcd client port |
2380 |
TCP |
VirtualNetwork |
VirtualNetwork |
etcd peer port |
6443 |
TCP |
Any |
Any |
Kubernetes API |
8472 |
UDP |
VirtualNetwork |
VirtualNetwork |
Flannel |
9345 |
TCP |
Any |
Any |
Kubernetes API |
10250 |
TCP |
VirtualNetwork |
VirtualNetwork |
kubelet |
30071 |
TCP |
VirtualNetwork |
VirtualNetwork |
NodePort |
Opening TCP ports on an Azure VM for multi-node installations
Create new inbound networking rules for the ports needed over TCP protocol.
