2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
This issue causes the RabbitMQ pod to be stuck in CrashLoopBackOff, with the log of the failing pod showing
wal_checksum_validation_failure as a reason.
To get a list of all pods, run the following command:
kubectl -n rabbitmq get podskubectl -n rabbitmq get podsTo get the logs of a pod, run the following command:
kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>To fix the issue, take the following steps:
Find the number of RabbitMQ replicas:
rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas')rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas') -
Scale down the RabbitMQ replicas:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=mergekubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=mergekubectl -n rabbitmq scale sts rabbitmq-server --replicas=0kubectl -n rabbitmq scale sts rabbitmq-server --replicas=0 -
Wait until all RabbitMQ pods are terminated:
kubectl -n rabbitmq get podkubectl -n rabbitmq get pod -
Check for pending volume snapshots:
kubectl get volumesnapshot -n rabbitmq <crashloopbackupoff_pod_pvc_name> | grep falsekubectl get volumesnapshot -n rabbitmq <crashloopbackupoff_pod_pvc_name> | grep false -
If any pending volume snapshot exists, delete it:
kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name>kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name> -
Find and delete the PVC of the RabbitMQ pod that is stuck in the CrashLoopBackOff state:
kubectl -n rabbitmq get pvckubectl -n rabbitmq get pvckubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name>kubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name> -
Scale up the RabbitMQ replicas:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=mergekubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=merge -
Check if all RabbitMQ pods are healthy:
