- Overview
- Requirements
- Accessing Automation Suite
- Managing the Certificates
- Resizing PVC
- Updating the SQL connection strings
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
The installation bundle provides a cluster management tool that enables you to update certificates post-installation. To access the tool, navigate to the location of the installer bundle:
cd /opt/UiPathAutomationSuite/cd /opt/UiPathAutomationSuite/To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr# copy the machine openssl configuration locally
[SAN]
EOF
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csrYour IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
To view more information about server certificates, run the following command:
sudo ./configureUiPathAS.sh tls-cert --helpsudo ./configureUiPathAS.sh tls-cert --helpOutput:
Manage cluster tls and server certificate
Usage:
configureUiPathAS.sh tls-cert [command]
configureUiPathAS.sh tls-cert [flags]
Available Commands:
update Update the tls / server certificate
get Get the tls / server certificate
Flags:
-h|--help Display help
Usage:
Available Commands:
Flags:
************************************************************************************./configureUiPathAS.sh tls-cert command.
Updating the server certificate
Online installation: How to find the server certificate
istio-ingressgateway-certs name in the istio-system namespace.
See the certificate files in the following list:
- Server TLS certificate is stored as
tls.crt - Server TLS private key as
tls.key - CA bundle is stored as
ca.crt
You can verify the secrets using the following command :
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yamlkubectl -n istio-system get secrets istio-ingressgateway-certs -o yamlCertificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, see Understanding the container architecture related to certificates.
Offline installation: How to find the server certificate
rootCA.crt and tls.crt: ArgoCD and Docker Registry. Certificates are then stored in both Docker and ArgoCD namespaces.
# For docker registry
kubectl -n docker-registry get secrets docker-registry-tls -o yaml
# For Argocd
argocd login alm.cluster_fqnd --username argocd_username --password argocd_password
argocd cert list --cert-type https# For docker registry
# For Argocd
argocd cert list --cert-type httpsHow to update server certificates
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key# replace /path/to/encrypted/cert/key to absolute file path of key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/keyconfigureUiPathAS.sh script to update the certificate as shown below. You need the path to each of the three certificate files. All the certificate
file should be in PEM format.
- Certificate Authority Bundle - This bundle should contain only the chain certificates used to sign the TLS server certificate. The chain limit is up to nine certificates.
- Server Certificate - Public server certificate
Private key - Private key for server certificate
sudo ./configureUiPathAS.sh tls-cert update --ca-cert-file /path/to/cacert --tls-cert-file /path/to/tlscert --tls-key-file /path/to/tlskeysudo ./configureUiPathAS.sh tls-cert update --ca-cert-file /path/to/cacert --tls-cert-file /path/to/tlscert --tls-key-file /path/to/tlskey
/directory/path/to/store/certificate location.
Accessing the TLS certificate
To print out the certificate files, run the following command, specifying the directory where certificates are stored.
sudo ./configureUiPathAS.sh tls-cert get --outpath /directory/path/to/store/certificatesudo ./configureUiPathAS.sh tls-cert get --outpath /directory/path/to/store/certificateAdding the CA certificate to the host trust store
You are responsible for making sure the generated certificates are trusted.
To add the certificate to the host VM trust store, run the following commands on all the nodes in the cluster:
# 1. Copy the certificate file to the /usr/share/pki/ca-trust-source/anchors/ or the /etc/pki/ca-trust/source/anchors/ directory
cp /path/to/the/ca-cert /usr/share/pki/ca-trust-source/anchors/
# 2. Update the trust store configuration
update-ca-trust# 1. Copy the certificate file to the /usr/share/pki/ca-trust-source/anchors/ or the /etc/pki/ca-trust/source/anchors/ directory
update-ca-trustTo view more information about additional CA certificates, run the following command:
./configureUiPathAS.sh additional-ca-certs --help./configureUiPathAS.sh additional-ca-certs --helpOutput:
Manage additional CA certificates, this can be used to add sql server CA
Usage:
configureUiPathAS.sh additional-ca-certs [command]
configureUiPathAS.sh additional-ca-certs [flags]
Available Commands:
update Update the additional trusted CA certificates.
get Get the additional trusted CA certificates
Flags:
Usage:
Available Commands:
Flags:
***************************************************************************************./configureUiPathAS.sh
additional-ca-certs command.
Updating the CA certificates
This command helps you update or replace the existing configured CA certificates.
./configureUiPathAS.sh additional-ca-certs update --ca-cert-file /path/to/ca/certs./configureUiPathAS.sh additional-ca-certs update --ca-cert-file /path/to/ca/certs--replace at the end.
.pem format and can have more than one certificate present in it.
Accessing the CA certificates
To download the already configured CA certificates, run the following command:
./configureUiPathAS.sh additional-ca-certs get --outpath /path/to/download/certs./configureUiPathAS.sh additional-ca-certs get --outpath /path/to/download/certsAdding the CA certificate to the host trust store
update-ca-trustTo view more information about identity token-signing certificates, run the following command:
sudo ./configureUiPathAS.sh identity token-cert --helpsudo ./configureUiPathAS.sh identity token-cert --helpOutput:
Manage Identity token signing certificate
Usage:
configureUiPathAS.sh identity token-cert [command]
configureUiPathAS.sh identity token-cert [flags]
Available Commands:
update Update secondary certificate to signing
the authentication token
rotate Switch secondary certificate as a primary
get Get token signing certificate
Flags:
Usage:
Available Commands:
Flags:
************************************************************************************./configureUiPathAS.sh identity
token-cert command.
Updating the Certificate
.pfx extension.
--password flag is between simple quotation marks. For example: --password 'CertificatePassword!@#'.
sudo ./configureUiPathAS.sh identity token-cert update --cert-file-path /path/to/cert --password '<cert_pass>'sudo ./configureUiPathAS.sh identity token-cert update --cert-file-path /path/to/cert --password '<cert_pass>'Rotating the Certificate
This will rotate or switch the old certificate with the new one uploaded using update certificate.
sudo ./configureUiPathAS.sh identity token-cert rotatesudo ./configureUiPathAS.sh identity token-cert rotateThere should be the lead time of about 24 - 48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
If you rotate the certificate too soon before the expiry of cache token can result in downtime. And you may have to restart all your robots.
Emergency Certificate Rotation
To perform an emergency certificate update, take the following steps:
Accessing the certificate
Run the following command to download the current token signing certificate:
sudo ./configureUiPathAS.sh identity token-cert get --outpath /directory/path/to/store/certificatesudo ./configureUiPathAS.sh identity token-cert get --outpath /directory/path/to/store/certificateBy default, RKE2 certificates expire in 12 months. In the 90 days prior to their expiration date, certificates are rotated when you restart RKE2.
For more details, refer to RKE2 - Advanced Options - Certificate rotation.
Checking the RKE2 certificate expiration date
if [[ -d "/var/lib/rancher/rke2/server/tls" ]]; then
dir="/var/lib/rancher/rke2/server/tls"
elif [[ -d "/var/lib/rancher/rke2/agent/tls" ]]; then
dir="/var/lib/rancher/rke2/agent/tls"
else
dir="/var/lib/rancher/rke2/agent/"
fi
# Loop through each .crt file in the directory
for file in "$dir"/*.crt; do
# Extract the expiry date from the certificate
expiry=$(openssl x509 -enddate -noout -in "$file" | cut -d= -f 2-)
# Get the file name without the path
filename=$(basename "$file")
# Print the filename and expiry date in a pretty format
printf "%-30s %s\n" "$filename:" "$expiry"
doneif [[ -d "/var/lib/rancher/rke2/server/tls" ]]; then
else
fi
doneThe output you get should be similar to the one shown in the following image:
Rotating the RKE2 certificate
By default, RKE2 certificates expire in 12 months. In the 90 days prior to their expiration date, certificates are rotated when you restart RKE2. However, if the validity of the certificates exceeds the 90-day period, you must manually rotate the certificates by following the steps mentioned in RKE2 - Advanced Options - Certificate rotation.
If you want to customize the expiration period of RKE2 certificates to meet particular requirements, you can do so before restarting the RKE2 services for both server and agent nodes.
To rotate the RKE2 certificates, you must first execute a series of action on the server nodes, then proceed with some steps on the agent nodes.
- Stop the RKE2 server:
systemctl stop rke2-server.servicesystemctl stop rke2-server.service - Clear any remaining RKE2 processes:
rke2-killall.shrke2-killall.sh - Delete the
dynamic-cert.jsonfile located at/var/lib/rancher/rke2/server/tls/. -
To customize the expiration period of the RKE2 certificates, use the following command. Be aware that this example sets the validity period to 1000 days, but you can change this value based on your requirements.
SERVICE_NAME="rke2-server.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reloadSERVICE_NAME="rke2-server.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reload - Restart the RKE2 server:
systemctl start rke2-server.servicesystemctl start rke2-server.serviceNote: If the cluster has more than one server node, steps 1-4 might not wholly execute as etcd may be unable to complete the leader election. Should this happen, repeat steps from 1-4 on other server nodes. - Delete the
rke2-servingsecret from thekube-systemnamespace:kubectl delete secret -n kube-system rke2-servingkubectl delete secret -n kube-system rke2-servingNote:In a multi-node deployment, you may not be able to run thekubectlcommands until you have completed the first four operations on the necessary number of server nodes. This is to fulfill the etcd quorum requirement. You can remove therke2-servingsecret immediately after the RKE2 server starts up.
kubectl get nodes command. When your server nodes are ready, you can proceed to the agent nodes to regenerate the certificates.
Take the following steps on the agent nodes:
systemctl stop rke2-agent.servicesystemctl stop rke2-agent.service - Clear any remaining RKE2 processes:
SERVICE_NAME="rke2-agent.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reloadSERVICE_NAME="rke2-agent.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reload - Restart the RKE2 server:
systemctl start rke2-agent.servicesystemctl start rke2-agent.service
- Generating a Certificate Signing Request (CSR) and a Private Key
- Managing server certificates
- Updating the server certificate
- Accessing the TLS certificate
- Adding the CA certificate to the host trust store
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Updating the Certificate
- Rotating the Certificate
- Emergency Certificate Rotation
- Accessing the certificate
- Managing RKE2 certificates
- Checking the RKE2 certificate expiration date
- Rotating the RKE2 certificate
