- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
As soon as you access a newly created tenant, you will notice that there is some predefined content already added in the Explore Automation Program,Explore Components,Manage Access - Assign Roles, and Application Inventory sections.
The purpose of this predefined dummy information is to help you understand the idea workflow and the component curation process through relevant examples. We highly recommend referring to it as an inspiring starting point in order to see how to fully benefit from using the Automation Hub platform.
The following predefined data is available:
                     Explore Automation Program Item Predefined Automation with Idea Source: Employee-driven 1 Onboarding of new employee 2 Import ideas to Automation Hub 3 Invoice Processing 4 Test Idea to Get You Started Item Predefined Automation with Idea Source: Citizen Developer 1 UiPath Use Case Creator 2 UiPath Projects Helper 3 UiPath Process Rollback Assistant 4 UiPath Package Deployment Assistant
                     Explore > Components Item Predefined Components 1 Test Component to Get You Started 2 Activity Creator 3 Google GSuite
                     Admin Console > Manage Access > Assign Roles Dummy User Status 1 Jane Doe Inactive
                     Admin Console > Platform Setup > App Inventory: applications used to document the above-mentioned ideas and reusable components.
To delete the predefined data, please follow the Deleting Data article.
