- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Email Types
- Email Content
- Email Settings
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Email Settings
Customize your email preferences by using the switch option available for each email type to enable/disable that email communication.
The Master Preferences option helps you enable/disable all email notifications from Automation Hub. To set up a specific email, search for its area, and the specific email type and then enable/disable it. Furthermore, using the Secondary Email Address field you can route your notifications to a different email address than the one set up when your account was created. This means that all the email notifications will be sent only to the secondary email address.
Access the Email Types page for details about each email sent from Automation Hub and Email Content to find a detailed list of the emails that you can receive from Automation Hub based on user roles and permissions.
