- Release Notes
- Getting Started
- Permissions
- Starting as- Starting as the Account Owner
- Starting as an RPA Sponsor
- Starting as a Component Curator
- Starting as a Program Manager
- Starting as an Idea Approver
- Starting as an Authorized User
- Starting as a Standard User
- Starting as a Citizen Developer Self User
- Starting as a Citizen Developer Power User
- Starting as a Business Reviewer
- Starting as a Technical Reviewer
- Understanding the Citizen Developer Flow
- Learn More With Courses From Academy
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated Oct 17, 2024
After successfully logging in, you, as a Citizen Developer Self User can explore the list of Automations submitted for your tenant and get inspired.
You are encouraged to share automations created for low-risk, simple tasks/activities from your daily work.
Within the Workspace module, you can have a detailed view over:
- Your automations;
- Your components;
- The Automation Pipeline;
- The Automations you follow.
By accessing the Explore module you can:
- view both the automations that are ready to consume as well as the submitted automations and choose to follow or show your interest for the ones that draw your attention,
- check out and download the components submitted within your tenant.
