Automation Hub User Guide
Last updated Oct 17, 2024
Audit Logs
By accessing the Audit Logs page the tenant's System Admin as well as other users with roles that have the permission to access the option, can view and download CSV reports containing information about the user activity on their Automation Hub tenant as well as Open API calls made.
The types of logs available in the Audit Logs section are:
  • Event Log - main report where you can find a list of all the events that happened, who performed them and time.
  • Open API - list of all the API calls performed on your Automation Hub Open API service - includes the entire request and response.
  • Tenant service - list of all the API calls performed on your Automation Hub instance - includes the entire request and response.
  • Object reference - list of API calls that too large to be displayed in the Tenant Service or Open API report.
To access the page go to Admin Console > Account -> Audit Logs.
Note: Audit Logs are stored for 30 days.
The table contains the following columns:
  • Service Name
  • Date Range
  • Size
  • Download button
  • View (button)
Service Name
Defines the type of service that the log is generated for.
Options:
Date Range
  • Represents the period for which the log is generated.
  • The logs are generated on a weekly basis - therefore the range will always be of 1 week.
  • The dates are generated by the system and cannot be controlled by the user.
Size
  • Represents the size of the log file expressed in kilobytes.
Download
  • The download button will be displayed in the “Download” column.
  • The button will allow the user to download the file and store it on his local machine.
  • The download button will not have limitations or restrictions - so the user can access and download the log at any time.
View
  • Will allow the user to visualize any of audit log report type from the page.
  • When clicked, it will open a table visualizer above the initial table that contains the Audit Log files.
  • Search will allow you to search in any column of the file.
  • Most common use case that we will recommend will be the search by “Action Name” in the Event Log report.
  • The visualizer also has pagination that enters into play after showing 210 lines of the report.
There are a couple of fields in the report which have also the option to copy the content of a specific field.
These fields are:
  • Action Info
  • Request Body
  • Response Body
  • Open API token
The response body and the request body are usually too large to show up in the visualizer. If that happens, they will show up like this {}
Event Log - Action Types
The list below is the complete list of events that can occur on tenant level and that can be included in the Action type:
Event Log - Action types
Event Id
Platform Event Name
Platform Event Slug
1
Idea Submitted
idea-submitted
2
Process Phase and Status Changed
process-phase-changed
3
Process Mark As Completed
process-mark-completed
4
User Profile Updated
user-profile-updated
5
Process Updated
process-updated
6
Process Document Added
process-document-added
7
Process Followed
process-followed
8
Process Upvoted
process-upvoted
9
Process Comment Added
process-comment-added
10
Process Comment Reply Added
process-comment-reply-added
11
Process Comment User Mentioned
process-comment-user-mentioned
12
Process Collaborator Role Assigned
process-collaborator-role-assigned
13
Reusable Component Added
reusable-component-added
14
Process Abuse Reported
process-abuse-reported
15
Component Status Changed
component-status-changed
16
Component Support Requested
component-support-requested
17
Component Abuse Reported
component-abuse-reported
18
User Invited to Join NavGo
send-user-invite-email
19
Email Verification Sent
email-verification-sent
20
Component Review Abuse Reported
component-review-abuse-reported
21
Process Comment Abuse Reported
process-abuse-comment-reported
22
Component Comment Abuse Reported
component-abuse-comment-reported
23
Process Collaborator Role Removed
process-collaborator-role-removed
24
Process Collaborator About Edit Rights Gran
process-collaborator-about-edit-rights-granted
25
Process Collaborator About Edit Rights Revo
process-collaborator-about-edit-rights-revoked
26
Process Owner Assigned
process-owner-assigned
27
Project Manager Assigned
project-manager-assigned
28
Process Document Updated
process-document-updated
29
Process Document Deleted
process-document-deleted
30
Direct Manager Added
direct-manager-added
31
Direct Manager Removed
direct-manager-removed
32
Admin Process Role Added
admin-process-role-added
33
Admin Process Role Updated
admin-process-role-updated
34
Admin Process Role Deleted
admin-process-role-deleted
35
Admin Template Doument Added
admin-template-document-added
36
Admin Template Doument Updated
admin-template-document-updated
37
Admin Template Doument Set Default
admin-template-document-set-default
38
Admin Process Role Enabled
admin-process-role-enabled
39
Admin Process Role Disabled
admin-process-role-disabled
40
Admin Template Deleted
admin-template-deleted
41
Process Collaborator Documentation Edit Ri
process-collaborator-documentation-edit-rights-granted
42
process-collaborator-documentation-edit-rights-revoked
43
Process Collaborator Removed From Certain
process-collaborator-certain-role-removed
44
Component Version Updated
component-version-updated
45
Project Manager Role Assigned
project-manager-role-assigned
46
Component updated
component-updated
47
CoE-driven Idea Submitted
coe-driven-idea-submitted
48
Reusable component removed
reusable-component-removed
49
System Admin added to user
system-admin-added-to-user
50
Program Manager added to user
program-manager-added-to-user
51
Curator added to user
curator-added-to-user
52
Assigned System admin
assigned-system-admin
53
System Admin removed from user
system-admin-removed-from-user
54
Program Manager removed from user
program-manager-removed-from-user
55
Curator removed from user
curator-removed-from-user
56
Process hierarchy updated
process-hierarchy-updated
57
Application inventory updated
application-inventory-updated
58
User's information updated
admin-users-information-updated
59
Assigned Program Manager
assigned-program-manager
60
Assigned Curator
assigned-curator
61
Removed as System Admin
removed-as-system-admin
62
Removed as Program Manager
removed-as-program-manager
63
Removed as Curator
removed-as-curator
64
Component Archived
component-archived
65
Component Updated for Downloaded Users
component-updated-for-downloaded-users
66
Component Uploaded for Curation
component-uploaded-for-curation
67
Component Curation Started
component-curation-started
68
Component Curation Reject
component-curation-reject
69
Component Curation Needs Update
component-curation-needs-update
70
Component Curation Publish
component-curation-publish
71
First User Standard Plan email
first-user-standard-email
72
First User Trial Plan email
first-user-trial-email
73
Component Downloaded
component-downloaded
74
Component Review Added
component-review-added
75
Component Comment Added
component-comment-added
76
Component New Reply
component-new-reply
77
Component User Mentioned
component-user-mentioned
78
Authorized User added to user
authorized-user-added-to-user
79
CoE Collaborator added to user
coe-collaborator-added-to-user
80
Assigned Authorized User
assigned-authorized-user
81
Assigned CoE Collaborator
assigned-coe-collaborator
82
Authorized User removed from user
authorized-user-removed-from-user
83
CoE Collaborator removed from user
coe-collaborator-removed-from-user
84
Removed as Authorized User
removed-as-authorized-user
85
Removed as CoE Collaborator
removed-as-coe-collaborator
86
Change Plan Dealhub email
changed-plan-dealhub-email
87
Change Plan Owner email
changed-plan-owner-email
88
Error email to Account Owner
changed-plan-error-email
89
Process Collaborator CBA Edit Rights Grante
process-collaborator-cba-edit-rights-granted
90
Extend Trial Granted
extend-trial-granted
91
User Sync Finished
user-sync-finished
92
User Deleted
user-deleted
93
Process Collaborator Components Edit Right
process-collaborator-components-edit-rights-granted
94
User Deactivated
user-deactivated
95
User Activated
user-activated
96
Component bug reported
component-bug-reported
97
CD Automation submitted
cd-automation-submitted
98
CD Automation shared
cd-automation-shared
99
CD Automation requested
cd-automation-requested
100
Automation Published
automation-published
101
Process Review Added
process-review-added
102
Process Question Added
process-question-added
103
Process Question Reply Added
process-question-reply-added
104
Process Review Updated
process-review-updated
105
Group Added
group-added
106
Group Deleted
group-deleted
107
Group Updated
group-updated
108
Automation Consumed
automation-consumed
109
User Added
user-added
110
User Updated
user-updated
111
User Mentioned In A Question
process-question-user-mentioned
112
User Login
log-in
113
User Logout
log-out
114
E-mail sent to the user
email-sent
Exporting Audit Logs Information as a .CSV File
You can download and retain the logs for the company's specific audit requirements. Each row of the table contains a log file that can be downloaded locally in a CSV file by clicking the Download button.
Note: Each entry in the file contains details for one specific action captured by the log.
The entry contains the following fields:
Field
userEmail
the e-mail of the user who performed the operation
userId
the User ID as registered in the data base
logType
the type of log
auditLogRequestId
the ID of the log entry
timestamp
the timestamp registered for the log
tenantId
the tenant UUID
tenantName
the tenant name
statusCode
the status code of the API request
responseBody
  • if applicable
requestBody
  • if applicable
query
the query object
logRequestDuration
the duration of the log request
logEndEpoch
the end time of the log request
cloudUserId
  • if applicable
logStartEpoch
the start time of the epoch log
URL
the endpoint URL
serviceName
Differentiates between the different services:
  • tenant - service
  • open - API
method
API method
openAPIToken
filled only for open - API service logs
Sample
