Automation Hub User Guide
Last updated Apr 15, 2025
Predefined Content From the Tenant
As soon as you access a newly created tenant, you will notice that there is some predefined content already added in the Explore Automation Program, Explore Components, Manage Access - Assign Roles, and Application Inventory sections.
The purpose of this predefined dummy information is to help you understand the idea flow and the component curation process through relevant examples. We highly recommend referring to it as an inspiring starting point in order to see how to fully benefit from using the Automation Hub platform.
Important: Please make sure to delete the predefined data, especially the dummy ideas so that it won't interfere with the information displayed in Dashboards or other tables that should only reflect your organization's information.
Predefined Data
The following predefined data is available:
  • Explore Automation Program
Item
Predefined Automation with Idea Source: Employee-driven
1
Onboarding of new employee
2
Import ideas to Automation Hub
3
Invoice Processing
4
Test Idea to Get You Started
Item
Predefined Automation with Idea Source: Citizen Developer
1
UiPath Use Case Creator
2
UiPath Projects Helper
3
UiPath Process Rollback Assistant
4
UiPath Package Deployment Assistant
  • Explore > Components
Item
Predefined Components
1
Test Component to Get You Started
2
Activity Creator
3
Google GSuite
  • Admin Console > Manage Access > Assign Roles
Dummy User
Status
1
Jane Doe
Inactive
  • Admin Console > Platform Setup > App Inventory: applications used to document the above-mentioned ideas and reusable components.
Deleting Predefined Data
To delete the predefined data, please follow the Deleting Data article.
  • Predefined Data
  • Deleting Predefined Data
