- Release notes
 - Getting Started
 - Permissions
 - Starting as
 - Admin Console
 - Workspace
 - Explore
 - Share Idea or Automation
 - Dashboards
 - My Tasks
 - Notifications
 - Email Notifications
 - Resources
 - Studio Integration
 - Task Capture Integration
 - Automation Store
 - Additional Resources
Automation Hub User Guide
Last updated Apr 15, 2025
After successfully logging in, you as a Component Curator need to focus on managing the RPA reusable components shared within your tenant.
By accessing Admin Console > Manage Components module, you have access to:
- an overview of all the tenant’s shared components,
 - update the Component Statuses whenever needed,
 - Curating a Component that are shared but not published yet.
You are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation.
Within the Workspace Overview module, you can have a detailed view over:
- Your collaborations;
 - Your components;
 - The Automation Pipeline;
 - The Ideas you follow.
- view the and choose to follow the ones that drow your attention,
 - check out and download the components shared within your tenant,
 - access the Leaderboard.
