- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
Update Automation Idea Phase and Status
linkUse this call to easily keep your Idea phase and status updated. Below you can find an example of how to make a call in which the Idea phase is updated to status Assessment in Progress.
Post:
https://{yourDomain}/automationhub_/api/v1/openapi/automations/status
Request
Headers
Authorization: Bearer [Tenant ID/Token]
x-ah-openapi-auth: openapi-token
data-raw '{
"process_id": 1183,
"phase_status_id": 53
Headers
data-raw '{
"process_id": 1183,
Response
"message": "Resource Updated",
"statusCode": 201,
"data": {
"message": "Sync Successful."
"statusCode": 201,
"data": {
