- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
OUT OF SUPPORT
Automation Hub API Guide for Automation Cloud
Last updated Nov 11, 2024
Short description:This video presents how to GET Automation Pipeline Data to Power BI and create custom dashboards.
The main topics are:
00:00 Intro
01:00 Setting up the connection from Power BI
04:00 Getting the API credentials from Automation Hub
04:45 Parsing the JSON response from the Open API
05:55 Formatting the table columns
08:15 Creating a dashboard from the imported data
