- Open API- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
Note:
         Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
| Key | Value | Use Case |
| hierarchy | The Category values are not defined as these fields are customized by each tenant. | GET and POST request parameters |
Note: You can easily extract the Category values relevant for your tenant by using the GET category call.
         Example: "category=717" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
UI Correspondent:
               Categories
