OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
Input for Detailed Assessment
Used for Submitting CoE-driven Ideas
Key
Key Type
Value
Use Case
Mandatory?
Automation Idea Name = process_name
Text input
Enter the name of the idea using the template.
POST request parameters
Yes
Automation Idea ID = orchestrator_automation_uuid
Text input
Enter the ID number you want to assign to your idea using the template.
No
Description = process_description
Text input
Enter the idea description using the template.
Yes
Automation Idea Area = category_id
ID input from Categories
You can easily extract Category ID by using the GET category call.
Yes
Pain Points = process_pain_points
Text input
Enter the pain points using the template.
Yes
Negative Impact = process_negative_impact
Text input
Enter the negative impact using the template.
Yes
Automation Idea Goal / Primary Reason to Automate the Process = automation_goal
Response choice
Cost = automation-goal-cost
Quality = automation-goal-quality
Productivity = automation-goal-productivity
Yes
Process Changes Expected in the Next 6 Months = task_stability
Response choice
No change expected = task-stability-no-change-expected
Minor change expected = task-stability-minor-change-expected
Some change expected = task-stability-some-change-expected
Several changes expected = task-stability-several-changes-expected
Major change expected = task-stability-major-change-expected
Yes
Applications Changes Expected in the Next 6 Months = application_stability
Response choice
No change expected = application-stability-no-change-expected
Minor change expected = application-stability-minor-change-expected
Some change expected = application-stability-some-change-expected
Several changes expected = application-stability-several-changes-expected
Major change expected = application-stability-major-change-expected
Yes
Average Working Days/Year = employee_average_working_days
Type: positive integer (rounded)
Enter the number corresponding to the average working days/year.
Yes
Working Hours/Day = employee_working_hours
Enter the number corresponding to the working hours/day.
Yes
Average Employee Full Cost/Year = employee_average_full_cost
Enter the number corresponding to the average employee full cost/year.
No
Task/Process Frequency = frequency
Response choice
Daily = frequency-daily
Weekly = frequency-weekly
Bi-weekly = frequency-bi-weekly
Monthly = frequency-monthly
Quarterly = frequency-quarterly
Yearly = frequency-yearly
Yes
Activity Volume Average = volumes
Enter the number corresponding to the activity volume average.
Yes
Average Processing Time/Transaction = average_handling_time
Enter the number corresponding to the average processing time/transaction.
Yes
Average Error Rate (% of Total Volume) = average_error_rate
Enter the number corresponding to the average error rate.
No
Average Rework Time/Transaction (min) = average_rework_time
Enter the number corresponding to the rework time.
No
Average Work to be Reviewed/Audited (% of Total Volume) = average_work_to_be_reviewed
Enter the number corresponding to the average rework time/transaction.
No
Average Review or Audit Time/Transaction (min) = average_review_audit_time
Enter the number corresponding to the average review or audit time/transaction.
No
Number of Employees Performing the Task = number_of_employees
Enter the value corresponding to the number of employees performing the task.
Yes
Process Peaks = process_peaks
Response choice
Regular (e.g. month closing) = process-peaks-regular
Rare but predictable event (e.g. winter holidays/ yearly closing) = process-peaks-rare-predictable
Rare and unpredictable event = process-peaks-rare-unpredictable
There are no peaks = process-peaks-no-peaks
Yes
Average Number of Steps = process_length
Response choice
Less than 20 steps = process-length-less-twenty
Between 20-50 Steps = process-length-between-twenty-fifty
Between 50-100 Steps = process-length-between-fifty-hundred
Between 100-150 Steps = process-length-between-hundred-hundredfifty
More than 150 Steps = process-length-more-than-hundredfifty
Yes
Number of Ways to Complete the Process = decision_complexity
Response choice
Process is completed the same way every time = decision-complexity-same-way
There are >=2 but <5 ways to complete the process = decision-complexity-between-two-five
There are >=5 but <8 ways to complete the process = decision-complexity-between-five-eight
There are >=8 ways to complete the process = decision-complexity-greater-eight
Yes
% of Digital Data Input = digital_inputs_percent
Enter the number corresponding to the % of digital data input.
Yes
Scanned Data Input = scanned_inputs
Boolean value
Yes = scanned-inputs-yes
No = scanned-inputs-no
Yes
% of Structured Digital Data Input = structured_input
Response choice
>= 80% = structured-input-greater-eighty
60%-80% = structured-input-between-sixty-eighty
40%-60% = structured-input-between-forty-sixty
<40% = structured-input-lesser-forty
Yes
Applications Used = applications
ID input from Applications
You can easily extract the Application ID by using the GET appinventory call.
Yes
Process Owner = owner
Process Owner email address
Yes
Example:
"process_name": "Coe Submission",
    "orchestrator_automation_uuid": "100024",
    "process_description": "automate the submission process",
    "category_id": 85,
    "process_pain_points": "painpoints_nostyle",
    "process_negative_impact": "not applicable",
    "automation_goal": "automation-goal-productivity",
    "task_stability": "task-stability-some-change-expected",
    "application_stability": "application-stability-several-changes-expected",
    "employee_average_working_days": "25",
    "employee_working_hours": "15",
    "employee_average_full_cost": "8934",
    "frequency": "frequency-weekly",
    "volumes": "7",
    "average_handling_time": "928",
    "average_error_rate": "3",
    "average_rework_time": "4",
    "average_work_to_be_reviewed": "12",
    "average_review_audit_time": "76",
    "number_of_employees": "8",
    "process_peaks": "process-peaks-rare-predictable",
    "process_length": "process-length-between-twenty-fifty",
    "decision_complexity": "decision-complexity-between-five-eight",
    "digital_inputs_percent": "7",
    "scanned_inputs": "scanned-inputs-yes",
    "structured_input": "structured-input-between-forty-sixty",
    "applications": [68,45],
    "owner": "[email protected]"
}    "process_name": "Coe Submission",
    "category_id": 85,
    "volumes": "7",
UI Correspondent: Submitting a CoE-driven Idea
