OUT OF SUPPORT
Automation Hub API Guide
Last updated Nov 11, 2024
API References
The Automation Hub API Swagger definition can be accessed directly by adding the Authentication details in the Authorization key in the request call named Header.
https://cloud.uipath.com/{orgName}/{tenantName}/automationhub_/api/v1/api-doc/
The guide herein is built to support the Swagger documentation, by providing relevant and easy to follow examples.
To use Swagger documentation in Delayed Release Organizations, use the following link:
If you prefer to work with Postman, create a Postman environment. Afterwards, check out our API collection made available in Postman. The collection can be imported by clicking the Run in Postman button.
