- Open API
- Introduction to Automation Hub API
 - API References
 - Generate your Token from Automation Hub
 - Input for Automation Pipeline
 - Input for Submission Type
 - Input for Phase
 - Input for Status
 - Input for Phase and Status Update
 - Input for Business Unit
 - Input for Applications
 - Input for Category
 - Input for Cost Benefit Analysis
 - Input for High Level Assessment
 - Input for Detailed Assessment
 - Input for Automation Idea Creation Date
 - Input for Users
 - Input for User Status
 - User Status Table
 - Input for Collaborators
- Output Dictionary
 - Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Used for Submitting the Employee-driven Ideas
                            Key  |
                            Value  |
                            Use Case  |
                            Mandatory?  |
                            How rule-based is your task? = rules  |
                            GET and POST request parameters  |
                            Yes  |
                            How would you describe the input data for your task/process? = input_type  |
                            Yes  |
                            How would you describe the structure of your input data? = input_quality  |
                            Yes  |
                            Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? = stability  |
                            Yes  |
                            Do you have any documentation regarding this process/activity?= documentation  |
                            Yes  |
                            The Idea submittersubmitter  |
                            Enter the submitter email address.  |
                            Yes  | |
                            The idea assigned Process Ownerowner  |
                            Enter the Process Owner email address.  |
                            Yes  | |
                            Automation Idea Name = process_name  |
                            Enter the name of the idea using the template.  |
                            POST request parameter  |
                            Yes  |
                            Description = process_description  |
                            Enter the idea description using the template.  |
                            Yes  |
                            Automation Idea Area = category_id  |
                            You can easily extract Category ID by using the GET category call.  |
                            Yes  |
"process_name": "InvoiceProcessing",
  "process_description": "Invoice data entry",
  "category": 717,
    "rules": 4,
    "input_type": 3,
    "input_quality": 5,
    "stability": 4,
    "documentation": 5,
    "submitter": "[email protected]",
    "owner": mary.doe@email.com1
}  "process_name": "InvoiceProcessing",
  "category": 717,
    "rules": 4,
    "input_type": 3,
    "input_quality": 5,
    "stability": 4,
    "documentation": 5,
    "owner": [email protected]
}UI Correspondent: Submit an Idea
