Automation Hub API Guide
Last updated Nov 11, 2024
Input for High Level Assessment
Used for Submitting the Employee-driven Ideas
Key
Value
Use Case
Mandatory?
How rule-based is your task? = rules
  • Very Creative = 1
  • Pretty Creative = 2
  • A mix between rules and creativity = 3
  • Pretty Rule Based = 4
  • Very Rule Based = 5
GET and POST request parameters
Yes
How would you describe the input data for your task/process? = input_type
  • Very Much Paperbased = 1
  • Pretty Much Paperbased= 2
  • A mix between digital and paperbased = 3
  • Pretty Much Digital = 4
  • Very Much Digital = 5
Yes
How would you describe the structure of your input data? = input_quality
  • Very much unstructured = 1
  • Pretty much unstructured = 2
  • A mix between structured and unstructured = 3
  • Pretty Much Structured = 4
  • Very Much Structured = 5
Yes
Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? = stability
  • Major Change Expected = 1
  • Several Changes Expected = 2
  • Some Change Expected = 3
  • Minor Change Expected = 4
  • No Change Expected = 5
Yes
Do you have any documentation regarding this process/activity?= documentation
  • Detailed Work Instructions = 5
  • Standard Operating Procedure = 4
  • Task/Process maps/flowcharts = 3
  • Input Files = 2
  • There is no documentation = 1
Yes
The Idea submittersubmitter
Enter the submitter email address.
Yes
The idea assigned Process Ownerowner
Enter the Process Owner email address.
Yes
Automation Idea Name = process_name
Enter the name of the idea using the template.
Yes
Description = process_description
Enter the idea description using the template.
Yes
Automation Idea Area = category_id
You can easily extract Category ID by using the GET category call.
Yes
Example:
"process_name": "InvoiceProcessing",
  "process_description": "Invoice data entry",
  "category": 717,
    "rules": 4,
    "input_type": 3,
    "input_quality": 5,
    "stability": 4,
    "documentation": 5,
    "submitter": "[email protected]",
    "owner": mary.doe@email.com1
}  "process_name": "InvoiceProcessing",
  "category": 717,
    "rules": 4,
    "input_type": 3,
    "input_quality": 5,
    "stability": 4,
    "documentation": 5,
    "owner": [email protected]
UI Correspondent: Submit an Idea
