- Open API
- Introduction to Automation Hub API
 - API References
 - Generate your Token from Automation Hub
 - Input for Automation Pipeline
 - Input for Submission Type
 - Input for Phase
 - Input for Status
 - Input for Phase and Status Update
 - Input for Business Unit
 - Input for Applications
 - Input for Category
 - Input for Cost Benefit Analysis
 - Input for High Level Assessment
 - Input for Detailed Assessment
 - Input for Automation Idea Creation Date
 - Input for Users
 - Input for User Status
 - User Status Table
 - Input for Collaborators
- Output Dictionary
 - Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Nov 11, 2024
Note:
         Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
                         Key  |
                         Value  |
                         Use Case  |
                         hierarchy  |
                         The Category values are not defined as these fields are customized by each tenant.  |
                         GET and POST request parameters  |
Note: You can easily extract the Category values relevant for your tenant by using the GET category call.
         Example: "category=717" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
UI Correspondent:
Categories
