- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Skipping host library creation
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Security and compliance
Security context for UiPath® services
This section provides details on the security context of the UiPath® services.
All UiPath® services are configured with a security context defined in their spec section.
The following sample shows a typical configuration for UiPath® services:
spec:
securityContext:
runAsNonRoot: true
runAsUser: 1000
runAsGroup: 1000
fsGroup: 1000
containers:
- securityContext:
allowPrivilegeEscalation: false
readOnlyRootFilesystem: true
capabilities:
drop: ["ALL"]
hostPID: false
hostNetwork: false
spec:
securityContext:
runAsNonRoot: true
runAsUser: 1000
runAsGroup: 1000
fsGroup: 1000
containers:
- securityContext:
capabilities:
drop: ["ALL"]
hostPID: false
hostNetwork: false
In some instances, the user IDs and group IDs can be greater than or equal to 1000, depending on your environment. Make sure you configure the user and group IDs according to your security principles and your organization's security guidelines.
Enabling FIPS 140-2
Federal Information Processing Standards 140-2 (FIPS 140-2) is a security standard that validates the effectiveness of cryptographic modules.
You can enable FIPS 140-2 on the machines on which you install Automation Suite in the following scenarios:
- Enable FIPS 140-2 before performing a clean installation of Automation Suite 2023.4 or later. For details, see. Enabling FIPS 140-2 for new installations
- Enable FIPS 140-2 after performing an Automation Suite installation on a machine with FIPS-140-2 disabled. For details, see Enabling FIPS 140-2 for existing installations.
The fips-mode-setup tool has been removed starting with RHEL 10. RHEL 10 requires FIPS mode to be enabled during OS installation. Switching to FIPS mode after installation is not supported in RHEL 10.
To enable FIPS 140-2 on the machines where you plan to perform a fresh installation of Automation Suite, take the following steps:
Before starting the Automation Suite installation, enable FIPS 140-2 on your machines.
For details, see Enabling FIPS 140-2.
Perform the Automation Suite installation by following the installation instructions in this guide.
Note:- If you install AI Center on a FIPS 140-2-enabled machine and also use Microsoft SQL Server, some additional configuration is required. For details, see SQL requirements for AI Center.
- Make sure Insights is disabled, as it does not currently support FIPS 140-2. If you need to use Insights, you can deploy it on a dedicated non-FIPS node. For details, refer to How to deploy Insights in a FIPS-enabled cluster.
Set the
fips_enabled_nodesflag totruein thecluster_config.jsonfile. -
Make sure your certificates are FIPS 140-2-compatible.
Note:By default, Automation Suite generates self-signed FIPS 140-2-compatible certificates whose expiry date depends on the type of Automation Suite installation you choose. We strongly recommend that you replace these self-signed certificates with CA-issued certificates at installation time. To use Automation Suite on FIPS 140-2-enabled machines, the newly provided certificates must be FIPS 140-2-compatible. For a list of eligible ciphers supported by RHEL, see the RHEL documentation.
- To update the token-signing certificates, run: assignment
./bin/uipathctl config token-signing-certificates update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey./bin/uipathctl config token-signing-certificates update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey- To update the TLS certificates, run: assignment
./bin/uipathctl config additional-ca-certificates update --ca-cert-file /path/to/ca/certs./bin/uipathctl config additional-ca-certificates update --ca-cert-file /path/to/ca/certs
You can install Automation Suite with FIPS 140-2 disabled, and then enable the security standard on the same machines. This is also possible when you upgrade to a new Automation Suite version.
To enable FIPS 140-2 on the machines where you already performed an Automation Suite installation, take the following steps:
Perform a regular Automation Suite installation or upgrade operation on machines with FIPS 140-2 disabled.
Enable FIPS 140-2 by running the following command on all your machines:
fips-mode-setup --enablefips-mode-setup --enable -
Note:To use Automation Suite on FIPS 140-2-enabled machines, you must replace your certificates with new FIPS 140-2-compatible certificates signed by a CA. For a list of eligible ciphers supported by RHEL, see RHEL documentation.
./bin/uipathctl config additional-ca-certificates update --ca-cert-file /path/to/ca/certs./bin/uipathctl config additional-ca-certificates update --ca-cert-file /path/to/ca/certsFor more on certificates, see Managing the certificates.
Make sure your product selection is in line with the FIPS-140-2 requirements:
- If you previously enabled Insights, you must disable it as it does not currently support FIPS 140-2. If you need to use Insights, you can deploy it on a dedicated non-FIPS node. For details, refer to How to deploy Insights in a FIPS-enabled cluster. For details on how to disable products post-installation, see Managing products.
Reboot your machines and check if you successfully enabled FIPS 140-2.
fips-mode-setup --checkfips-mode-setup --check -
Rerun the
uipathctlinstaller:- In an online environment, run:
./bin/uipathctl rke2 install -i cluster_config.json -o output.json -s --accept-license-agreement - Online -- online./bin/uipathctl rke2 install -i cluster_config.json -o output.json -s --accept-license-agreement - Online -- online - In an offline environment, run:
./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -s --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -s --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
