- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
uipath namespace instead of a custom namespace and want to move from one Automation Suite flavor to another. We support the following
scenarios:
Migrate from Automation Suite on Linux to a new installation of Automation Suite on EKS/AKS;
Migrate from Automation Suite on EKS/AKS to a new installation of Automation Suite on OpenShift;
Migrate from Automation Suite on OpenShift to a new installation of Automation Suite on EKS/AKS;
Migrate from Automation Suite on EKS to Automation Suite on AKS or from Automation Suite on AKS to Automation Suite on EKS.
Note that you can attempt to perform the migration operation multiple times with no impact on your existing cluster.
The following migration scenarios are not supported:
Migrating from Automation Suite on Linux to an existing installation of Automation on EKS/AKS or Automation Suite on OpenShift;
Migrating an Automation Suite on OpenShift cluster to Automation Suite on Linux cluster.
Step |
Description |
1. |
Mandatory. Make sure you meet the migration requirements. |
2. |
Mandatory. Prepare the target cluster and the docker images for both source and target cluster. Optional. If your deployment is offline or if you use a private OCI registry, make sure the required images are available. |
3. |
Mandatory. Start the migration, move the data, and run the Automation Suite installation. |
4. |
Optional. If AI Center is enabled on both the source and target clusters, migrate the skills. |
For detailed migration instructions, see the Automation Suite on EKS/AKS Installation Guide.
