- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Due to the way in which the GCP Marketplace deployments work, it is not possible to wait until the installation scripts are finished. The deployment is completed after the infrastructure is successfully deployed.
To get the status of the installation, you must use SSH to connect to the first server node using the following steps:
The installation process generates self-signed certificates on your behalf. These certificates are compliant with FIPS 140-2 and will expire in 90 days. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they arecompatible with FIPS 140-2.
For instructions, see Managing certificates.
After completing an Automation Suite installation using the GCP deployment template, you can enable FIPS 140-2 on your machines. For instructions, see Security and compliance.
Solution output section, as shown in the following image:
The outputs give you the necessary information for accessing the suite and the cluster.
The following table describes the values:
Key |
Description |
The fully qualified domain name provided for the installation. Make sure you use the same one when configuring the DNS. For instructions on how to configure the DNS, see Configuring the DNS. |
The load balancer’s IP address used for configuring the DNS. |
The IP address of the bastion VM needed to access the cluster via SSH. |
The deployment ID included in the name of all the resources in a deployment. |
The URL to the secret containing the credentials for the database. |
The URL to the secret containing the credentials for the Host organization in the Automation Suite portal. |
The URL to the secret containing the credentials for the ArgoCD console used to manage the installed products. |
The URL to dashboard (Grafana) monitoring tools:
https://monitoring.${var.lb_fqdn}/dashboard |
The URL to metrics (Prometheus) monitoring tools:
https://monitoring.${var.lb_fqdn}/metrics |
The URL to Alertmanager monitoring tools:
https://monitoring.${var.lb_fqdn}/alertmanager |
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.To access the services, you must have a DNS configured. For details, see Configuring the DNS.
Alternatively, you can follow the instructions in Configuring a client machine to access the cluster for testing purposes only.
If using a self-signed certificate, you may get an certificate error as shown in the following image.
Select Proceed to…, then update the cluster certificates as explained in Managing the certificates.
https://<fqdn>. You can get the credentials via a secret available at:
As Host CredentialsURL for the Host organization;As Default CredentialsURL for the Default organization.
https://alm.<fqdn>. You can get the credentials via a secret that can be found at the argocd_credentials URL.
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
- Password: to retrieve the
password , run the following
command:
kubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decodekubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decode
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
Run the following command to update the password:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
To access the cluster machines via SSH, make sure to configure and use SSH in the browser. For details, see Google documentation.
Use the GPC console to edit number of nodes (server or agent nodes) as follows:
- Checking the installation status
- Updating certificates
- Enabling FIPS 140-2
- Accessing the deployment outputs
- Output definitions
- Accessing the Cluster Administration portal
- Accessing the services
- Accessing the Automation Suite portal
- Accessing ArgoCD
- Accessing the monitoring tools
- Accessing the cluster
- Editing the number of nodes
- Removing the deployment
