- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Saving robot logs to an Elasticsearch server can be achieved through two types of configuration: basic and advanced.
The basic configuration provides default functionality that activates the preconfigured Elasticsearch NLog target, which is made up of an Elasticsearch target wrapped in a Buffering target. This type of configuration is enough in most scenarios.
However, if you need to further customize the rules, you can use the advanced configuration method.
To apply the basic configuration, take the following steps. For more details, see Configuring the Orchestrator parameters.
The basic configuration supports Elasticsearch version 7.x. For Elasticsearch 8.x, you need to use the advanced configuration.
NLog.config target.
- Follow the basic configuration steps described previously.
- Follow the Advanced NLog configuration steps, then update the
robotElasticBuffertarget with the properties that need to be changed.
The advanced configuration also supports Elasticsearch version 8.x.
nlog.config.json for Elasticsearch 7.x
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
}nlog.config.json for Elasticsearch 8.x
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
