Last updated Nov 13, 2025
Deployment architecture
Terminology
For more information on the core concepts used in an Automation Suite deployment, refer to Glossary.
Deployment modes and use cases
Automation Suite supports the following deployment modes:
Deployment mode
Single-node — default mode
By default, supported for evaluation and demo scenarios.
Multi-node — production, HA-enabled
Supported for production use.
You can choose between two varieties of multi-node mode:
  • Lite mode
    By default, the infrastructure and shared components are set to HA mode, while all services are set to non-HA (horizontal pod autoscaling is enabled with a minimum of one replica). You can set specific services to HA. You also have the option of performing additional configuration post-deployment to have full HA capabilities.
  • HA mode
    Fully enabled HA, with either in-cluster high availability or external high availability.
Note: Single-node (evaluation) deployments can be converted to high availability (HA) setups by adding the additional hardware required for multi-node deployments. For more details, refer to the Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment page.
Automation Suite uses a cloud native architecture based on Kubernetes. It provides all the benefits in scale, automatic resource management, and reliability that come with Kubernetes.
To offer these benefits, the Kubernetes design is based on the following fundamental aspects:
  • Running on an uneven number of multiple machines (3, 5, 7, etc.);
  • Using the quorum principle to handle independent node failures and data corruption. For a cluster of N machines, as long as there is still a number of N/2 + 1 machines that have quorum, the cluster is functional and can recover gracefully with no observed failures.
This page offers insight into the Automation Suite architecture and describes the components bundled into the installer.
Node types
A server node hosts cluster management services (control plane) that perform important cluster operations such as workload orchestration, cluster state management, load balance incoming requests, etc. Kubernetes may also run a few of the UiPath® products and shared components based on underlying resource availability.
An agent node is responsible for running the UiPath® products and shared components only.
A specialized agent node runs special workloads like Task Mining analysis, Document Understanding pipelines that require GPU capability, or Automation Suite Robots. However, the core Task Mining, Document Understanding, or Automation Suite Robots services still run on the server or agent nodes. Specialized agent nodes do not host any of the UiPath® product or shared components.
Important: Automation Suite cannot guarantee which UiPath® product runs on each node. This is solely managed by Kubernetes.
Single-node evaluation deployment
A single-node evaluation deployment here means a single-server node. This does not imply the deployment of the entire Automation Suite on a single machine. You may have to add additional agent or specialized agent nodes if the entire product suite cannot fit in a single server node, or if you want to run special tasks like Task Mining analysis and Document understanding pipelines, which require GPU capabilities.
Lite mode deployment
The lite mode is a lightweight deployment that demands less from your infrastructure resources. It provides flexibility with its high configurability for services requiring high availability. By default, the infrastructure and shared components are deployed in HA mode, and all services are in lite mode. You can switch specific services to HA mode.
Important: You can use lite mode in production, but you must be aware of the implications and risks of having services without high availability enabled.
Multi-node HA-ready production deployment
A multi-node HA-ready production deployment involves 3 or more server nodes behind a load balancer. This is to ensure that, in the event of disaster, when any of the server nodes goes down, Automation suite is still available to perform critical business workflows. The number of agent nodes is optional and is based on actual usage.
High Availability Add-on
In a multi-node setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services is running on a single pod and represents a single point of failure. To mitigate the impact of a cache node failure or restart, you can purchase the High Availability Add-on (HAA), which enables redundant, multi-pod deployment of the cache.
For more details on how to enable HAA in a multi-node setup, see Enabling High Availability Add-on for the cluster.
Online deployment
An online deployment means Automation Suite requires access to the internet during both installation and runtime. All the UiPath® products and supporting libraries are hosted either in UiPath® registry or UiPath-trusted third party store.
You can restrict access to the internet with the help of either a restricted firewall or a proxy server, by blocking all the traffic over the internet other than what is required by Automation Suite. This type of setup is also known as semi-online deployment. For more details, see Configuring the firewall and Configuring the proxy server.
These types of deployments are easier, faster, and require fewer hardware resources to install and manage as compared to offline deployments.
Offline deployment
An offline deployment (air-gapped) is a completely isolated setup without access to the internet. This kind of setup requires the installation of an additional registry to store all the UiPath® products' container images and binaries, which are shipped in the form of tarball.
Note:
Uploading binaries (hydration) to the registry introduces additional hardware requirements and installation complexity, increasing the time required to perform an installation as compared to an online deployment.
An offline installation increases not only the complexity during installation, but also the cluster management operations like machine maintenance, disaster recovery, upgrading to newer versions, applying security patches, etc.
You are not allowed to change the deployment method post-installation. This means that you cannot change to offline if the installation is done online and vice versa. It is recommended to choose your deployment strategy after careful consideration.
The following diagram depicts the Automation Suite architecture. Note that the Docker registry and the S3-compatible objectstore can also be hosted externally.
The following table lists out the third-party components shipped with Automation Suite:
Component
Optional/Required
RKE2
Required
Rancher-provided Kubernetes distribution. It is the container orchestration platform that runs all the architectural components and services.
CEPH Object Store
Optional if you have an external objectstore
Open-source storage provider that exposes Amazon S3-compliant object/blob storage. It enables services to use blob storage like functionality for their operations.
Argo CD
Required
Open-source declarative CD tool for Kubernetes. It follows the GitOps pattern of using Git repositories as the source of truth for defining the desired application state. It provides application lifecycle management (ALM) capabilities for Automation Suite components and UiPath® services that run in a Kubernetes cluster.
Docker registry
Optional if you have an external registry
Open-source docker registry used for pushing and pulling install time and runtime container images in your premises.
Istio
Required
Open-source service mesh that provides functionality such as ingress, request routing, traffic monitoring etc., for the microservices running inside the Kubernetes cluster.
Prometheus
Required
Open-source system monitoring toolkit for Kubernetes. It can scrape or accept metrics from Kubernetes components as well as workloads running in the clusters and store those in time series database.
Grafana
Required
Open-source visualization tool used for querying and visualizing data stored in Prometheus. You can create and ship a variety of dashboards for cluster and service monitoring.
Alertmanager
Required
Open-source tool that helps handling alerts sent by client applications such as the Prometheus server. It is responsible for deduplicating, grouping, and routing them to the correct receiver integrations, such as email, PagerDuty, or OpsGenie.
Redis
Required
Redis Enterprise non-HA (single shard) used by some UiPath® services to get centralized cache functionality.
FluentD and Fluentbit
Required
Open-source reliable log scraping solution. The logging operator deploys and configures a background process on every node to collect container and application logs from the node file system.
Gatekeeper
Required
Open-source tool that allows a Kubernetes administrator to implement policies for ensuring compliance and best practices in their cluster.
Velero
Required1
Open-source tool that allows you to take a snapshot backup and restore.
Thanos
Required
Open-source tool to push the Prometheus matrix to an objectstore for persistence.
1 Only installed during backup and restore.
External components
You also need to bring a few external components, such as external load balancers and an SQL server. Note that the suite provides some extension points.
