Last updated Apr 22, 2026
How to disable streaming logs for AI Center
To disable log streaming on existing skills, edit the skill deployment and change the LOGS_STREAMING_ENABLED environment variable to false.
You can also add a logsStreamingEnabled global variable with the value set as false using ArgoCD under the aicenter app details. Make sure to sync ArgoCD after the change is done.
docs image
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
