Process Mining
Last updated Sep 24, 2025
2023.10.11
Release date: September 24, 2025
We are constantly striving to improve your UiPath® Process Mining experience. While this release brings no major changes, we included security and accessibility improvements, as well as minor bug fixes.
Important: Action required for OAuth connections to Salesforce
Salesforce announced restrictions to the use of connected apps.
If you use a connection to Salesforce for Loading data using CData Sync, the connection may be disrupted. If you authenticate the connection with Salesforce using OAuth, you must take action to maintain your connection.
Actions required
Your Salesforce Org Admin should install the CData Connector app (or your organization’s app).
  1. Log into Salesforce and go to Setup.
  2. Navigate to Connected Apps OAuth Usage.
  3. Find the CData Connector and select Install.
  4. Select Install again to confim.
Refer to the following articles for more information:
Support for CData Sync 25.2.9369
We now support CData Sync 25.2.9369 for Loading data using CData Sync. Read more about the updates in the official CData Sync documentation.
Workspace Management
CData Sync 25.2.9369 includes Workspace Management. Workspaces allow you to organize connections, jobs, and access policies, and make it possible to restrict user access to specific connections or jobs.
Refer to the official CData Sync documentation on Workspace Management for more information.
Upgrade CData Sync
Check out for more information on upgrading to CData Sync 25.2.9369.
