Last updated Aug 11, 2025
Supported profile use cases
The single-node mode is only suitable for evaluation purposes, whereas you can use the multi-node profile in production.
Note: Single-node (evaluation) deployments can be converted to high availability (HA) setups by adding the additional hardware required for multi-node deployments. For more details, refer to the Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment page.
Automation Suite supports the following deployment modes, each targeted at specific use cases, as explained in the following table:
Deployment mode
Single-node — evaluation
Supported only for evaluation and demo scenarios.
Multi-node — production, HA-enabled
  • Lite:
    Supported for production deployments.
    Non-HA by default, but you can set specific services to HA.
  • HA: Supported for production deployments. You can perform additional configuration post-deployment to have full HA capabilities.
Context and considerations
Automation Suite uses a cloud native architecture based on Kubernetes. It provides all the benefits in scale, automatic resource management, and reliability that come with Kubernetes.
To offer these benefits, the Kubernetes design is based on the following fundamental aspects:
  • Running on an uneven number of multiple machines (3, 5, 7, etc.);
  • Using the quorum principle to handle independent node failures and data corruption. For a cluster of N machines, as long as there is still a number of N/2 + 1 machines that have quorum, the cluster is functional and can recover gracefully with no observed failures.
Single-node installations
By definition, single-node deployments do not benefit from the previously described characteristics and are not supported for production deployments. Failures and data loss can and will occur. In case of failure, data recovery for single-node deployments without backup is not supported.
However, since support for single-node deployments is valuable for evaluation and demo scenarios, UiPath® offers this deployment option applicable to some specific use cases.
Multi-node installations
Lite mode installations
Lite mode offers a resource-light method for setting up Automation Suite. Lite mode ensures flexible infrastructure management by allowing you to enable high availability for specific services during or after installation, as needed.
Important:
You can use lite mode in production, but you must be aware of the implications and risks of having services without high availability enabled.
HA installations
Multi-node installations are supported for production deployments, with all the previously mentioned benefits.
  • Supported profile use cases
  • Context and considerations
  • Single-node installations
  • Multi-node installations
  • Lite mode installations
  • HA installations
