- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
Attempting to restore a backup in Automation Suite 2024.10.0 results in the following
error:
time="2024-11-18T08:13:48Z" level=info msg="Listing restore from namespace velero"
time="2024-11-18T09:28:35Z" level=info msg="Restore rst-000001-as wait for completion failed at namespace velero: restore PartiallyFailed"
Error: could not restore backup: restore PartiallyFailedtime="2024-11-18T08:13:48Z" level=info msg="Listing restore from namespace velero"
Error: could not restore backup: restore PartiallyFailedThe problem occurs due to a Dapr sync issue. We fixed the issue in Automation Suite 2024.10.1.
To address the issue, take the following steps:
To check if the restore process failed due to a Dapr sync issue, take the following steps:
Check if the hook failed by running the following command:
velero restore describe <restore-name>velero restore describe <restore-name>If the hook failed, the output of the command looks similar to the following example:HooksAttempted: 1 HooksFailed: 1HooksAttempted: 1 HooksFailed: 1 -
In case of hook failure, check the logs of the restore process by running the following command:
velero restore logs <restore-name> | grep 'dapr\\" not found'velero restore logs <restore-name> | grep 'dapr\\" not found'If a Dapr sync issue caused the hook failure, the output of the command looks similar to the following example:'App cert-manager is synced and healthy'\n++ date +%Y-%m-%dT%H:%M:%S%z\n+ echo '[INFO] [2024-11-18T04:28:35-0500]: App cert-manager is synced and healthy'\n+ for app in ${apps[@]}\n+ set +x\nError from server (NotFound): applications.argoproj.io \"dapr\" not found\n\x1b[0;31m[ERROR][2024-11-18T04:28:35-0500]:\x1b[0m Failed to fetch argocd app=dapr\n" hookCommand="[/bin/bash -c OP=restore RESTORE_NAME=mytstbackup bash /script/backup-restore-rke2.sh]" hookContainer=backup-hook-service hookName=restore-rke2-hook hookOnError=Fail hookPhase=post hookSource=spec hookTimeout="{5h0m0s}" hookType=exec logSource="pkg/podexec/pod_command_executor.go:180" pod=uipath-infra/backup-hook-service-78769845d7-x8hkq restore=velero/rst-000001-as'App cert-manager is synced and healthy'\n++ date +%Y-%m-%dT%H:%M:%S%z\n+ echo '[INFO] [2024-11-18T04:28:35-0500]: App cert-manager is synced and healthy'\n+ for app in ${apps[@]}\n+ set +x\nError from server (NotFound): applications.argoproj.io \"dapr\" not found\n\x1b[0;31m[ERROR][2024-11-18T04:28:35-0500]:\x1b[0m Failed to fetch argocd app=dapr\n" hookCommand="[/bin/bash -c OP=restore RESTORE_NAME=mytstbackup bash /script/backup-restore-rke2.sh]" hookContainer=backup-hook-service hookName=restore-rke2-hook hookOnError=Fail hookPhase=post hookSource=spec hookTimeout="{5h0m0s}" hookType=exec logSource="pkg/podexec/pod_command_executor.go:180" pod=uipath-infra/backup-hook-service-78769845d7-x8hkq restore=velero/rst-000001-as
To address the partial failure of the restore process, take the following steps:
Modify the hook configuration by running the following command:
kubectl get cm -n uipath-infra backup-hook-script-cm -o yaml | sed "s/alerts auth cert-manager dapr event-listener gatekeeper goldpinger logging/alerts auth cert-manager event-listener gatekeeper goldpinger logging/g" | kubectl apply -f -kubectl get cm -n uipath-infra backup-hook-script-cm -o yaml | sed "s/alerts auth cert-manager dapr event-listener gatekeeper goldpinger logging/alerts auth cert-manager event-listener gatekeeper goldpinger logging/g" | kubectl apply -f - -
Rerun the restore process by using the
uipathctltool.
