Last updated Nov 13, 2025
Audit Logs Queries
Prerequisites
Before downloading audit logs for Apps in the Automation Suite setup, the following requirements must be met:
  • You must have access to the machine or virtual machine (VM) where UiPath® services are hosted.
Optionally, you need to know the following:
  • Organization name for which the audit logs are needed (<orgName>).
  • User email for whom the audit logs need to be exported or deleted (<userEmail>).
  • Number of days between now and the day you want to get or delete audit logs for (<numDays>).
Getting Audit Logs Queries
SELECT document FROM [UipathApps].[audit-logs]
WHERE JSON_VALUE(document, '$.__tenantId') = '<orgName>' and
JSON_VALUE(document, '$.userInfo.userEmail') = '<userEmail>' and
CONVERT(datetime, JSON_VALUE(document, '$.createdAtDate')) <= (getdate() - <numDays>)SELECT document FROM [UipathApps].[audit-logs]
Deleting Audit Logs
DELETE FROM [UipathApps].[audit-logs]
CONVERT(datetime, JSON_VALUE(document, '$.createdAtDate')) <= (getdate() - <numDays>)DELETE FROM [UipathApps].[audit-logs]
  • Prerequisites
  • Getting Audit Logs Queries
  • Deleting Audit Logs
