Last updated Nov 13, 2025
Manual: Preparing the installation
Important: To ensure a smooth and uninterrupted SSH session, we strongly recommend that you follow the steps in Installation best practices before installing Automation Suite.
To prepare the installation, take the following steps:
Step
1.Download the installation packages and get the files on the Automation Suite machine
2.
Configure the OCI-compliant registry for offline installations
3.
Configure the external objectstore
4.
5.
Configure Microsoft SQL Server
6.
Configure the load balancer
7.
Configure the DNS
8.
Configuring kernel and OS level settings
9.
Configure the disks
10.
Configure the node ports
11.
Apply miscellaneous settings
12.
Validate and install the required RPM packages
13.
Generate cluster_config.json
14.
Apply advanced configuration
15.
Configure the temporary Docker registry for offline installations
16.
Validate the prerequisites for the installation
