Last updated Nov 13, 2025
Kinit: Keytab contains no suitable keys for *** while getting initial credentials
This error could be found in the log of a failed job, with one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Solution
Make sure the AD user still exists, is active, and their password was not changed and did not expire. Reset the user's password and regenerate the keytab if needed.
Also make sure to provide the default Kerberos AD user parameter <KERB_DEFAULT_USERNAME> in the following format: HTTP/<Service Fabric FQDN>.
  • Description
  • Solution
