OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
About uipathctl
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
For more information, including a complete list of uipathctl operations, see the uipathctl reference documentation.
You can install uipathctl on the Linux, macOS, and Windows platforms.
Note:
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
