- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
About uipathctl
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
About uipathctl
uipathctl
is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
For more information, including a complete list of
uipathctl
operations, see the uipathctl reference documentation.
You can install
uipathctl
on the Linux, macOS, and Windows platforms.
Note:
Currently,
uipathctl
is only compatible with the x86 architecture.
You cannot run uipathctl
on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
