- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
A load balancer is mandatory for the multi-node HA-ready production setup.
x-forwarded-for header to the request it sends to the server. This header includes the original client's IP address. The server can then
read this header to retrieve the client's IP address.
Automation Suite supports two types of configuration for the load balancer, as shown in the following sections.
You can configure the load balancer to use session persistence or sticky sessions, but it is not a requirement.
Currently, Automation Suite supports Layer 4 (network layer) load balancers. Layer 7 (application layer) load balancers are also supported. For details, refer to Configuring the L7 Load Balancer (Optional).
The load balancer does not support TLS encryption and termination. For effective service operation, make sure to configure your load balancer to facilitate traffic pass-through.
If you are using the Azure Internal Load Balancer (LB) for deployments, you can encounter issues with the calls from the backend Virtual Machine (VM) to the LB frontend IP. The issues occur due to source IP and MAC address mismatch of the network packet. This prevents the recipient from working out the correct response path, resulting in the failure of calls from the VM to the LB. For more details, see Azure Load Balancer Components limitations and Backend Traffic Troubleshooting.
This is the recommended configuration for the load balancer.
Configuring the backend pool
You must create three backend pools that meet the following requirements:
Server Pool
- Consists of all the server nodes.
- There must not be any agent nodes in the Server Pool.
Node Pool
Consists of all the server nodes and non-specialized agent nodes. Specialized agent nodes include
gpu, andasrobots.
Temporary Registry Pool
Consists only of the server node where the Temporary Registry is installed.
Note:The Temporary Registry Pool is used only during the Automation Suite installation, node joining, and upgrade procedures. After you complete the procedures, you can close the Temporary Registry Pool.
Configuring the health probes
Probe |
Protocol |
Port |
Interval |
Re-entry threshold |
Associate pool |
TCP |
15 sec |
2 |
Node Pool |
TCP |
15 sec |
2 |
Server Pool |
Refer to the following illustration for more details on the configuration:
Enabling ports on the load balancer
Ensure you have the following ports enabled on your firewall for the source of load balancer:
Port |
Protocol |
Purpose |
Traffic forwarding |
Health probe |
TCP |
For HTTPS (accessing Automation Suite). |
Traffic on this port must be forwarded to Node Pool. |
300701 |
TCP |
For accessing the temporary registry during installation and upgrade using HTTP. |
Traffic on this port must be forwarded to the Temporary Registry Pool. |
N/A |
TCP |
For accessing Kube API using HTTPS; required for node joining. |
Traffic on this port should be forwarded to Server Pool. |
TCP |
30070 on the load balancer and the server node on which you plan to install the temporary docker registry.
We recommend not exposing any ports except for the HTTPS one outside the cluster. Run your nodes behind a firewall / security group.
If you have a firewall set up on the network, make sure that it has these ports open to allow traffic.
This configuration does not have resilience to nodes going down during installation.
If the primary server is down or deleted, cluster configuration needs to be updated.
FQDN of the primary server needs to be remapped to a different machine in the cluster that is available.
Create one backend Pool, as follows:
- Create a Node Pool
Ensure that you have the following ports enabled on your firewall for the source of load balancer:
Port |
Protocol |
Purpose |
TCP |
Traffic on this port should be forwarded to the Node Pool. |
Probe |
Protocol |
Port |
Interval |
Associate pool |
TCP |
15 sec |
2 |
Node Pool |
Refer to the following illustration for more details on the configuration.
