- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
Once a cluster is restored, the snapshot backup is not enabled. To enable it after restore, see Enabling the backup snapshot.
Restoring the cluster does not restore external data sources such as SQL Server, objectstore, or the OCI-compliant registry. Make sure to restore these datasource to the relevant snapshot.
To restore the cluster, take the following steps:
- Install the cluster infrastructure on all the server nodes. Details...Note:
The hardware you provide for the restore cluster must be similar to the backup cluster hardware. For details, see Hardware and software requirements.
- Configure the snapshot on the restored cluster. Details...
- Select the snapshot to restore. Details...
- Restore the data and settings. Details...
Preparation
- Download the restore installer. You can find it inside the
as-installer.zippackage. For download instructions, see Downloading the installation packages. - In offline environments, you must provide an external OCI-compliant registry or a temporary registry. Note that the registry
configuration must remain the same as the one of the original cluster. To configure the registry, see the following instructions:
- Configuring the external OCI-compliant registry
- Configuring the temporary Docker registry. Choose this option only if you did not use an external OCI-compliant registry before the disaster occurred.
- Prepare the configuration file and make it available on all the cluster nodes. To prepare the configuration file, take one
of the following steps:
- Option A: Reuse the
cluster_config.jsonfile that you applied to the cluster before the disaster occurred; - Option B: Create a minimal
cluster_config.jsonfile with the required parameters, as shown in the following example:{ "fixed_rke_address": "fqdn", "fqdn": "fqdn", "rke_token": "guid", "profile": "cluster_profile", "external_object_storage": { "enabled": false }, "install_type": "offline or online", "snapshot": { "enabled": true, "nfs": { "server": "nfs_server_endpoint", "location": "nfs_server_mountpoint" } }, "proxy": { "enabled": false } }{ "fixed_rke_address": "fqdn", "fqdn": "fqdn", "rke_token": "guid", "profile": "cluster_profile", "external_object_storage": { "enabled": false }, "install_type": "offline or online", "snapshot": { "enabled": true, "nfs": { "server": "nfs_server_endpoint", "location": "nfs_server_mountpoint" } }, "proxy": { "enabled": false } }Note:This example uses parameters for an NFS-based backup configuration.
If you use a different backup configuration, you must replace the NFS-related section with the parameters specific to your backup configuration.
cluster_config.json file. Make sure to provide the same parameter values as the ones used in the orginal cluster. You can change the parameter
values post-restore.
cluster_config.json parameters listed in the following table, you must also provide the external OCI-compliant registry configuration. For details,
see External OCI-compliant registry configuration.
Parameter |
Value |
FQDN of the Automation Suite cluster. The value must be the same as the old FQDN. Providing a different FQDN value may cause the restoration to fail. |
The fixed address used to load balance node registration and Kube API requests. If the load balancer is configured as recommended, the value should be the same value as the one for
fqdn. Otherwise, use the fqdn value of the first server node. Refer to Configuring the load balancer for more details.
Use a newly generated GUID here. This is a pre-shared, cluster-specific secret. It is needed for all the nodes joining the cluster. |
Sets the profile of the installation. The available profiles are:
Indicates the type of installation you plan to perform. Your options are:
| The FQDN or the IP address of the snapshot storage location (such as mynfs.mycompany.com or 192.23.222.81).
| The location or path to the snapshot storage location. |
| The path to the custom directory used for pod logs. This is required if the cluster was configured with custom pod logs path. |
This parameter is mandatory only if the proxy is enabled. For details, see Optional: Configuring the proxy server. |
cluster_config.json, see Manual: Advanced installation experience.
Execution
Installing the cluster infrastructure on the primary server node
To install the infrastructure on the primary restore cluster node, run the following commands:
cd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json --accept-license-agreement --restorecd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json --accept-license-agreement --restorecluster_config.json from the primary server node to the remaining server/agents nodes. The infrastructure installation step on the primary server
node adds extra values that the remaining nodes need.
Installing the cluster infrastructure on secondary servers
To install the infrastructure on the secondary servers:
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j server --accept-license-agreement --restorecd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j server --accept-license-agreement --restoreInstalling the infrastructure on all the agent machines
To install the infrastructure on the agent nodes:
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j agent --accept-license-agreement --restorecd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j agent --accept-license-agreement --restoreHydrating the in-cluster registry for offline installations
This step is required only if you use an in-cluster registry for offline installations. You must hydrate the registry before you trigger the restore, by using the following command:
./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.json./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.json Installing the cluster infrastructure on service nodes
Installing the cluster infrastructure on Automation Suite Robots nodes
To install the cluster infrastructure on Automation Suite Robots nodes:
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j asrobots --accept-license-agreement --restorecd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j asrobots --accept-license-agreement --restoreInstalling the cluster infrastructure on GPU nodes
To install the cluster infrastructure on GPU nodes:
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j gpu --accept-license-agreement --restorecd <installer directory>
./bin/uipathctl rke2 install -i ../../cluster_config.json -o output.json -j gpu --accept-license-agreement --restoreOnce the infrastructure is installed, you need to prepare the cluster snapshot for restore. Based on your scenario, you must run the following commands:
If you use an external objectore:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --only velero --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --only velero --versions versions/helm-charts.json
If you use an in-cluster ceph-objectstore:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --only base,rook-ceph-operator,rook-ceph-object-store,velero --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --only base,rook-ceph-operator,rook-ceph-object-store,velero --versions versions/helm-charts.json
To configure the backup of the restored cluster, follow the steps in the Configure the cluster snapshot section.
After configuring the snapshot, list the existing snapshots and decide on the one you want to use as a restoring point.
--from-snapshot <snapshot-name> flag.
./bin/uipathctl snapshot restore create <restore_name> --from-snapshot <snapshot_name>./bin/uipathctl snapshot restore create <restore_name> --from-snapshot <snapshot_name>The command triggers the restore process. The process first restores the backup, then performs Automation Suite related tasks. When in-cluster Ceph storage is configured, it additionally restores Ceph data before synchronizing the applications.
restore create command with a new name. The retry resumes the restore process from the step where it failed during the previous attempt.
./bin/uipathctl snapshot restore history./bin/uipathctl snapshot restore historyThis command shows only the status of restoring the cluster state (Kubernetes resources).
restore create command.
If you do not specify the snapshot name, the cluster restores the latest successful snapshot. See the snapshot list for available snapshots.
Restoring cluster_config.json
cluster_config.json file for future usage, such as adding new nodes to the cluster, upgrading, etc.
cluster_config.json, take the following steps:
You need to find the last applied configuration, by running the following command:
The following sample is an example of the command output:./bin/uipathctl manifest list-revisions./bin/uipathctl manifest list-revisionsVERSION UPDATED STATUS 1 2024-11-07 00:46:41 +0000 UTC successful 2 2024-11-07 01:14:20 +0000 UTC successful 3 2024-11-07 01:23:23 +0000 UTC successfulVERSION UPDATED STATUS 1 2024-11-07 00:46:41 +0000 UTC successful 2 2024-11-07 01:14:20 +0000 UTC successful 3 2024-11-07 01:23:23 +0000 UTC successful -
Select the correct VERSION number deployed before backup creation and run the following command to retrieve the
cluster_config.jsonfile:./bin/uipathctl manifest get-revision --version <VERSION>./bin/uipathctl manifest get-revision --version <VERSION>The following sample is an example of the command output:
./bin/uipathctl manifest get-revision --version 1 > ./cluster_config.json./bin/uipathctl manifest get-revision --version 1 > ./cluster_config.json
Adding CA certificates to the trust store
After restoring the cluster, make sure to add your CA certificates to the trust store of the restored VMs. For details, see:
Retrieving new monitoring password
After restoring an Automation Suite cluster, you need to retrieve the new monitoring password. For this, follow the steps from Accessing the monitoring tools.
Enabling AI Center on the Restored Cluster
After restoring an Automation Suite cluster with AI Center™ enabled, follow the steps from the Enabling AI Center on the Restored Cluster procedure.
Generating new Kerberos ticket
If Kerberos authentication is set up, you must make sure that the Kerberos ticket is not expired.
To generate a new Kerberos ticket, run the following commands:
kubectl get cronjobs -A | grep kerberos //to identify the job with name kerberos-tgt-update
kubectl create job --from=cronjob/<cron-job-name> <new_job_name> -n <namespace>kubectl get cronjobs -A | grep kerberos //to identify the job with name kerberos-tgt-update
kubectl create job --from=cronjob/<cron-job-name> <new_job_name> -n <namespace><cron-job-name>, <new_job_name>, and <namespace> with the actual name of your cron job, the intended name for the new job, and your actual namespace respectively.
- Step 1: Installing the cluster infrastructure
- Preparation
- Execution
- Step 2: Preparing the cluster for restore
- Step 3: Selecting the snapshot to restore
- Step 4: Restoring data and settings
- Restoring cluster_config.json
- Adding CA certificates to the trust store
- Retrieving new monitoring password
- Enabling AI Center on the Restored Cluster
- Generating new Kerberos ticket
