Last updated Apr 21, 2026
Optional: Passing custom resolv.conf
The Kubernetes cluster that Automation Suite deploys uses the name servers configured in /etc/resolv.conf. Kubernetes does not work with local DNS resolvers (127.0.0.1 or 127.0.0.0/8), so if you have such name servers configured in /etc/resolv.conf file, you need to pass a file reference with the correct nameserver entries accessible from anywhere on the VM in the .infra.custom_dns_resolver parameter in cluster_config.json.
For details on a known limitation, see Kubernetes documentation.
Optional ParametersDescription
.infra.custom_dns_resolverPath to the file with correct name server entries that can be accessed from anywhere on the VM. These name server entries must not be from 127.0.0.0/8.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
