- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Accessing the Models
- Enabling or disabling Extended Languages OCR
- Allocating GPU resources for Document Understanding modern projects
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
For optimal performance, allocating the appropriate number of GPU resources is vital. You allocate GPU resources through ArgoCD, which contains specific parameters that correspond to each service. By adjusting these parameters, you can control the distribution of GPU resources as per the needs of each service.
Each service listed in the capacity calculator has a corresponding ArgoCD parameter as follows:
- OCR replicas corresponds to the
du-ocr-saas.replicaCountparameter. - Custom model training replicas corresponds to the
du-training-ssde.replicasparameter. - Custom model replicas corresponds to the
du-aimodelhost-2404.replicasparameter. - OOB model replicas corresponds to the
du-ssde-saas.replicaCountparameter.
Before allocating of GPU resources to each service, use the capacity calculator to determine the appropriate number of GPUs that should be allocated to each service. The output is based on your specific needs and will serve as a guide when updating the parameters in ArgoCD.
