- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
TLS 1.2 has vulnerabilities related to weak cipher implementation. If you use TLS 1.2, you must take one of the following steps:
- Option A: Upgrade to TLS 1.3
- Option B: Use TLS 1.2 and modify your cypher suite to address kube API server TLS issues
To upgrade to TLS 1.3, take the following steps:
Modify the configuration of the primary TLS listener in Automation Suite, which operates on port 443. To do that, update the value of the
istioMinProtocolVersionparameter in thecluster_config.jsonfile toTLSV1_3. -
Re-run the Automation Suite installation by running the following command:
./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-charts.json -
Update the kube API server to TLS 1.3. The kube API server operates on port 6443. To perform the upgrade, add the following line to your
config.yamlfile:sed -i '/kube-apiserver-arg:/a\ - "tls-min-version=VersionTLS13"' /etc/rancher/rke2/config.yamlsed -i '/kube-apiserver-arg:/a\ - "tls-min-version=VersionTLS13"' /etc/rancher/rke2/config.yaml -
Restart the RKE2 server. Note that this step may cause temporary downtime.
systemctl restart rke2-serversystemctl restart rke2-server
To continue using TLS 1.2 and fortify your system's security, take the following steps. Note that the following steps address
the kube API server TLS issues.
Modify your cipher suite by inserting the following line into your
config.yaml. The configuration line must include the parameters of the ciphers that you want to allow.sed -i '/kube-apiserver-arg:/a\ - "tls-cipher-suites=TLS_CHACHA20_POLY1305_SHA256,TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA,TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_256_CBC_SHA,TLS_RSA_WITH_AES_256_GCM_SHA384"' /etc/rancher/rke2/config.yamlsed -i '/kube-apiserver-arg:/a\ - "tls-cipher-suites=TLS_CHACHA20_POLY1305_SHA256,TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA,TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_256_CBC_SHA,TLS_RSA_WITH_AES_256_GCM_SHA384"' /etc/rancher/rke2/config.yaml -
