- Release notes
 - Before you begin
- Installing Automation Suite
 - Process Mining configuration checklist
 - System requirements
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Customizing process apps
 - App templates
 - Additional resources
- Out-of-the-box Tags and Due dates
 - Editing data transformations in a local environment
 - Designing an event log
 - Extending the SAP Ariba extraction tool
 - Performance characteristics
Process Mining
Last updated Sep 24, 2025
After installing and enabling Process Mining on your on-premises (Automation Suite) environment, make sure to check the list present in this guide that evaluates if Process Mining is working properly.
