- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Customizing process apps
 - App templates
 - Additional resources
- Out-of-the-box Tags and Due dates
 - Editing data transformations in a local environment
 - Designing an event log
 - Extending the SAP Ariba extraction tool
 - Performance characteristics
Process Mining
Last updated Sep 24, 2025
Note: The information in this page is based on CData Sync 25.2.9369. If you use an other version of CData Sync, field names or functions may be different.
         Note: For a POC, you can request CData for a Free Trial version of CData Sync. Go to the official CData Sync website to sign up
               and download CData-Sync - Free Trial.
            CData Sync is a tool that is used to extract data from source systems into Process Mining. The supported source systems can be found on the Sources page on the CData Sync website. Refer to the official CData Sync website for more information on CData Sync.
         This page describes how to use CData Sync to load data from your source system into a process app in Process Mining.
It is assumed that you have:
- a valid CData Sync license.
                  Note: The license is provided via UiPath® for the purpose of Process Mining.
 - set up SQL Server access with the correct permissions. Refer to
CData Sync includes Workspace Management. Workspaces allow you to organize connections, jobs, and access policies, and make it possible to restrict user access to specific connections or jobs.
Refer to the official CData Sync documentation on Workspace Management for more information.
