- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Working with process apps
- Working with dashboards and charts
 - Working with process graphs
 - Working with Discover process models and Import BPMN models
 - Showing or hiding the menu
 - Context information
 - Export
 - Filters
 - Sending automation ideas to UiPath® Automation Hub
 - Tags
 - Due dates
 - Compare
 - Conformance checking
 - Root cause analysis
 - Simulating automation potential
 - Viewing Process data
 - Creating apps
 - Loading data
 - Customizing process apps
 - App templates
 - Additional resources
- Out-of-the-box Tags and Due dates
 - Editing data transformations in a local environment
 - Designing an event log
 - Extending the SAP Ariba extraction tool
 - Performance characteristics
Process Mining
Message: [Errno 2] No such file or directory: '/dbt/dags/workflows/execdbt//target/4212eba4-1edc-4b9c-9c04-1d59c2bfe0af/run_results.json'
Possible cause
The content of the uploaded transformation package is incorrect, by an incorrect zip action.
Solution
.zip file that contains the transformations is correct.
                  Possible cause
enableSqlIntegratedAuth configuration flag determines whether or not integrated SQL authentication setup is used for SQL authentication. If the enableSqlIntegratedAuth configuration flag is set to true, this implies that Kerberos setup is not used for authentication. To solve the issue, the enableSqlIntegratedAuth configuration flag must set to false which disables integrated SQL authentication and ensures that Kerberos setup is used for authentication.
                  Possible solution
enableSqlIntegratedAuth flag to false.
In the ArgoCD Experience, enter Airflow in the search bar and open the card.
Select App Details and go to the Details tab.
                        Edit the VALUES and set the flag
enableSqlIntegratedAuthto false. Select SAVE. -
                        Locate the SYNC POLICY section and set AUTOMATED to DISABLE AUTO-SYNC for the Airflow app, to ensure the configuration flag
enableSqlIntegratedAuthwill not be brought back to true.
Possible cause
One or more input files you uploaded have an unexpected encoding.
Solution
Set the encoding to UTF-8 and set CR/LF end of line characters (Windows style).
You can change these settings in a file editor. For example in Notepad++.
1. Open the datasource file in Notepad++.
2. Go to Edit -> EOL Conversion and select Windows CR LF.
3. Go to Encoding and select Convert to UTF-8.
4. Save the file.
Possible cause
Incorrect or missing HTTPS certificate.
Solution
The HTTPS certificate used by the BLOB store must be valid in your browser. Check the error and make sure to get the appropriate certificates.
1. Go the Process Mining portal and press F12 to open the Developer tools.
When creating a new process app using sample data, the following error message can occur:
Possible cause
A SQL Server password has changed. Check out Configuring Microsoft SQL Server.
Solution
Update Automation Suite when changing SQL Server credentials.
- Message: [Errno 2] No such file or directory: '/dbt/dags/workflows/execdbt//target/4212eba4-1edc-4b9c-9c04-1d59c2bfe0af/run_results.json'
 - Possible cause
 - Solution
 - Possible cause
 - Possible solution
 - Message: utf-8 codec can't decode byte <byte> in position <position>: Invalid start byte
 - Possible cause
 - Solution
 - Message: File upload failed due to the following error: Network error
 - Possible cause
 - Solution
 - Message: The HTTP status code of the response was not expected (500)
 - Possible cause
 - Solution
