- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
Loading data using Theobald Xtract Universal
Process Mining
Last updated Jun 26, 2025
This page describes how to use Theobald Xtract Universal (XU) to load data from your SAP source system into a process app. Refer to the official Theobald Software website for more information on Theobald Xtract Universal (XU).
Theobald Xtract Universal provides fast data access and extractions to SAP ECC and SAP HANA data sources. For general instructions on how to use Theobald Xtract Universal, check out the official Theobald Software documentation Getting Started with Theobald Xtract Universal.
It is assumed that you have:
- a valid Theobald Xtract Universal license.
Note:
The license is provided via UiPath® for the purpose of Process Mining.
- set up SQL Server access with the correct permissions. Check out
Note: Loading data using Theobald Xtract Universal requires that the command line tool (
xu.exe
) can be executed without additional authentication.
Setting up data load using Theobald Xtract Universal requires several steps to be performed.
- Set up Theobald Xtract Universal
- Import the template extractions
- Configure the source
- Configure the destination
- Configure the extraction script
- Run the extraction script
