uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2 node
Rotate kubernetes cluster nodes.
Options
-h, --help   help for node -h, --help   help for node
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
