uipathctl reference guide
Last updated Apr 28, 2025
uipathctl registry upload
Upload the optional offline bundle.
uipathctl registry upload [flags]uipathctl registry upload [flags]
Options
-h, --help                             help for upload
      --offline-bundle string            Specify the path to the offline bundle
      --offline-tmp-folder string        Specify parent directory for the temporary offline install folder
      --optional-offline-bundle string   Specify the path to the optional offline bundle  -h, --help                             help for upload
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
