uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config kerberos-auth global-config
Manage global Kerberos authentication.
Options
-h, --help   help for global-config-h, --help   help for global-config
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
