- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
Change the Orchestrator custom configuration.
uipathctl config orchestrator [flags]uipathctl config orchestrator [flags]--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 5h0m0s)
--versions string optional path to versions file --context string name of the kubeconfig context to use
