uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2
Manage the rke2 specific configurations
uipathctl rke2 [flags]uipathctl rke2 [flags]
Options
-h, --help   help for rke2  -h, --help   help for rke2
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
