OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl sso generate-rbac
Generate a sample RBAC configuration file for ArgoCD. For details, see ArgoCD documentation.
uipathctl sso generate-rbac [flags]uipathctl sso generate-rbac [flags]
Examples
Generate a sample rbac configuration file for ArgoCD:
Options
-h, --help   help for generate-rbac  -h, --help   help for generate-rbac
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
