- Overview
- Pre-installation
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Runs the prerequisite checks to validate that the installation would succeed.
uipathctl prereq run PATH [flags]uipathctl prereq run PATH [flags]# Runs all the prerequisite checks
uipathctl prereq run input.json --versions versions.json
uipathctl prereq run input.json --versions versions.json-h, --help help for run
--versions string path to versions file -h, --help help for run
--versions string path to versions file--context string name of the kubeconfig context to use
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
