OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot restore
Restore the cluster from the snapshot.
uipathctl snapshot restore [flags]uipathctl snapshot restore [flags]
Options
-h, --help   help for restore  -h, --help   help for restore
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
