OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl config additional-ca-certificates update
Append the additional CA certificates from the provided path to the ones already existing in the cluster.
The current additional CA certificates from the cluster are overwritten. The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config additional-ca-certificates update [flags]uipathctl config additional-ca-certificates update [flags]
Examples
# Append to the existing additional ca certificates from the cluster
        uipathctl config additional-ca-certificates update --cacert additional_ca.crt
        # Overwrite the current additional ca certificates from the cluster
        uipathctl config additional-ca-certificates update --cacert additional_ca.crt --replace
        # Append to the existing additional ca certificates from the cluster identified by the current context in the kubeconfig file
        uipathctl config additional-ca-certificates update --cacert additional_ca.crt --kubeconfig cluster.kubeconfig
Options
--cacert string   path to additional ca certificates
  -h, --help            help for update-additional-ca-certificates
  -r, --replace         if true, the existing additional ca certificates are overwritten--cacert string   path to additional ca certificates
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
