OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl snapshot list
Show the list of the snapshot backups.
uipathctl snapshot list [flags]uipathctl snapshot list [flags]
Options
-h, --help   help for list  -h, --help   help for list
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
